2016-2018 KTM 350 TPS setting
endurox
Garden City, ID US
Anybody know the best setting for the TPS on the Husky?KTM 350 sx or xc-f models. Set from factory at .59 but stalls easily, adjusted to .79 and is better but still not great. Old 350 engine set at .611 volts worked well.
thanks
Monk
10/12/2017 9:44pm
There is no "standard" for best setting... Every bike is different.. .79v seems awful high though...
captmoto
Rancho Cucamonga, CA US
10/12/2017 10:40pm
That's a big jump. Some of the DS bikes are set at .58 and guys are setting at .64. Any more than that and you need to start working on the timing. My FC450 was set at .50, now at .56 but got a little harder to start so I'm going back to .54 TPStool guy recommends moving up .02 at time and test each setting.
CarlinoJoeVideo
Portland/Los Angeles, CA US
2339th
10/12/2017 10:45pm
endurox wrote:
Anybody know the best setting for the TPS on the Husky?KTM 350 sx or xc-f models. Set from factory at .59 but stalls easily, adjusted to...
thanks
If it stalls easy why not just raise your idle?
tek14
Vantaa FI
10/13/2017 12:21am
Because TPS setting will be better tool to modify.
I wouldn't go up more than 0.08-0.10v. This was case with 450f anyway.
Benton, LA US
10/13/2017 10:09am
If your are setting the TPS that high it indicates a fuel flow issue and a lean condition. Test the fuel injector and check the fuel filters and the fuel pump.
endurox
Garden City, ID US
10/13/2017 3:46pm
Paw Paw wrote:
If your are setting the TPS that high it indicates a fuel flow issue and a lean condition. Test the fuel injector and check the fuel...
My mistake, had set it to .568 as stock was .529. Will try the .64 and I did install the best dual sport fuel rail and fuel filter.
endurox
Garden City, ID US
10/13/2017 7:03pm
Works way better at .64, thanks for the input
Post a reply to: 2016-2018 KTM 350 TPS setting
