2015 KX250F wont start
Rockinar
Katy, TX US
2015 KX250 wont start. It will start with the choke on. When you push it back in, it dies.
Ideas? Maybe need valve adjustment? It's a 2015 but it probably only has 5 hours on it.
Benton, LA US
6/22/2017 2:55pm
Do you have the idle set too low?
Rockinar
Katy, TX US
6/22/2017 4:32pm
Here's what happens.
When I set the idle low (10 clicks out or so) it won't start at all, no matter choke on or off. If I set it high 25 clicks or so, it will start withe the choke on, but then it revs REALLY high......WHAAAAAAA! like the motor is going to blow up so I turn the choke off, and the motor dies.
Benton, LA US
6/22/2017 9:00pm
Check your TPS sensor as it may be out of adjustment. A clogged fuel filter can also be an issue.
pCp 252
Hampden, MA US
2541st
6/22/2017 11:13pm
Do you have any good info on how to check tps sensor on this throttle body? I have a 2015 kx250f with low hours, and it too has trouble starting occasionally. Sometimes it starts first kick, a few other times it has taken 25 Kicks on the stand before it fires up. I actually thought I may have chipped a valve seat so I just replaced the top end and cleaned up the valve train. Everything was in great shape and didn't really even need to be replaced.
I have noticed my bike starts more consistently with what I considered just a slightly high idle. Too low of an idle I also experienced a few flame outs.
I have heard checking the fuel filter on this fuel pump is not a good idea, as it will not go back together as it did from the factory. Is this true?
Also I have heard ECU mapping can play a role in this. Some say you can remap to help fire the bike up.
By the way, my kick technique is much different than a 2 stroke. Relatively slow & smooth kick starting from TDC.
Thank you!
Tracktor
The RTF/Amboy, WA US
6/23/2017 10:04am
May not be related but ours had a hanging idle. I had just rebuilt the top end and adjusted the valves so I knew that was all goo. The fix was screw the adjustment all the way in then back out to set. It even ran a bit better after that but runs/starts best with idle a bit higher than stock.....
Acidreamer
Mansfield, OH US
6/23/2017 1:45pm Edited Date/Time 6/23/2017 1:46pm
pCp 252 wrote:
Do you have any good info on how to check tps sensor on this throttle body? I have a 2015 kx250f with low hours, and it...
Thank you!
I believe you need a volt/ohm reader. The rotation of the sensor will change the reading. Make sure its in the spec your service manual specifies.
Rockinar
Katy, TX US
6/23/2017 8:31pm
Anyone know where to get a service manual (2015 250F)? The Kawasaki website shows them not available. There's a couple website that say they have them, but the website's look sketchy and I dont see any on Ebay.
Post a reply to: 2015 KX250F wont start
