Auburn, AL
Over the weekend we managed to do some troubleshooting with my bike and it has left me with following question before ordering the new part.
After testing the the majority of the wiring we found one with no continuity between the ground and injector plug. The manual says this is the symptoms of a faulty ECU. Has anyone ever experienced this? Does this sound logical to you electronically savvy fellas?
I also wanted to inquire about the option of testing with a fellow riders ECU. He has the same bike, but his ECU has been mapped. Would it in anyway, shape, form or fashion put his in jeopardy to try to fire mine up with his connected? I can't afford two ECU's.
Side note: The bike will not start without placing the gas or spraying ether directly into it. So the injector has been suspect for some time. Just now got around to being able to play with it some.
Thanks in advance,
Sidney
Thanks in advance,
Sidney
Sorry for not including that in the original post.
Any clue as to if it would cause issues for mine or my buddies mapped ECM just to try and fire it up real quick?
Also don't forget to check the TPS sensor. If it is not working ( or set correctly) it can also shut off fuel flow.
Been a busy week thus far. I will update with the end result of the ECU test.
Cheers.
So, the one thing I didn't want to do was jus throw money at but it seems we have. We have a new injector and a new ECU. What's left that controls the injector's spray pattern/amount? The TPS, condenser, rectifier? Per pawpaw I was thinking of buying a new TPS sensor but it appears it's only available as a whole unit with the throttle body? Can I buy it separately? Anyone got any idea what part I should replace next. The OP is my son if there's any confusion..lol
It was mentioned but we used a stator from a working bike and it made no difference. So, we've eliminated the stator, ecm, and injector. We also changed the sock on the fuel filter. I dont' think the pump is a problem. You can just leave the fuel line plugged into the tank and undo the end at the injector and hang the line out the side of the bike and kick it over and copious amounts of fuel come flowing out.
It looks like out next try is the TPS but I'll entertain other ideas. Paw Paw have you ever seen a TPS go bad on one of these bikes?
It ended up being a bad fuel pump which we thought we had eliminated as a possible cause. I had undone the fuel line and kicked the bike over and it would pour out plenty of gas as you kicked it, indicating that it was working. I had even hooked the pump up to an electrical source and watched it shoot fuel out the pump.
Per Paw Paw, I had rigged up a device to check the tps (thanks TT for the instruction on the homemade tester) and it checked out fine. We had even purchased one(throttle body as tps is only available that way) ahead of time. Well in the midst of removing the tank and all the stock tank pump just started pouring fuel when removed. I was like well hell the check valve just took a shit. So for f@cks sake lets throw this other tank we have over here on the bike (our friend had just dropped off his 2012) and low and behold the damn thing cranked.
Had that check valve not taken a crap I would not have found this problem.
I just wanted to update everyone as I hate when you are reading a thread and the ending never gets posted.
Thanks guys for all the advice.
Gerald
Post a reply to: 2015 CRF250R ECU QUESTION
