Santa Clarita, CA
I’m sure this has been posted a million times already, so I’m not 100 percent sure if my drain plug is stripped but it still threads into the bottom of the case. Not sure what the cheapest and quickest fix would be to do any suggestions (maybe some sort of oversized drain plug bolt?) I’m not exactly an expert in working on bikes but I desperately need help!
No shame paying someone to do it.
True, the proper way is time cert the hole.
In emergencies I was shown something that worked from some way old dude.
Old dude took an american thread bolt, it was barley larger than the original drain bolt by just a hair.
He used a grinding wheel and made the end of the bolt hex like a tap, just at the tip.
He used the bolt as a tap and it cut threads and held tight, I was impressed.
Post a reply to: 2014 rmz250 oil drain plug stripped?
