2006 YZ 125 crank identification
PremixKid
St. George, UT US
Edited Date/Time 8/6/2017 7:07am
Hello guys,
My yz started to run really hot last time I rode it so I ran a leak down test on it and it failed, psi dropped from 6 to 4 is about 1 minute. So we are planing on replacing both crank seals and also a new piston.
We we pulled the cylinder off we noticed it was ported and also had a oversize piston in it. But the crank has these weird grooves machined into it.
Has anyone ever seen this before? I googled stock cranks and all the photos showed a smooth crank.
Any ideas on these grooves? Also when I got the bike the jetting was very rich, we bought all stock jets and got it close, but not perfect. Anyone has any starting points for 144 jetting? I live at 5000 feet.
Thanks
paddyB745
novato, CA US
8/4/2017 9:10pm
Looks like someone's attempt at a "turbo" crank. Never seen it done like that before though.
rmoto003
Gulf Shores, AL US
8/4/2017 9:51pm
Ah see you got the inverse reduction amplification crank modulator. Helps mix the gas and the oil together, like a blender kind of.
slipdog
Nor Cal, CA US
8/5/2017 8:10am
CrGuy2T
Santa Fe, TX US
3711th
8/5/2017 1:25pm Edited Date/Time 8/5/2017 1:27pm
that's basically a helical gear cut. I'm not to sure of the exact purpose but, my guess it's to force the excel premix in to the main bearings. It will also lighten the crank significantly along with an even machine probably pretty easy to balance.
PremixKid
St. George, UT US
8/5/2017 8:50pm
Thanks guys, getting the cylinder replated and ordering seals soon. Still would like to know the story behind this crank.
kzizok
AS US
2034th
8/6/2017 4:37pm
Slip,
You are one funny motherscratcher! I literally LOL'd!
Post a reply to: 2006 YZ 125 crank identification
