2005 ktm 65sx throttle cable to tight
my throttle cable is to tight and when i turn my bars cable does not let the bars move and throttle tube has no play
please help
racer369
MO US
10/27/2017 10:35am
you have cable in front of bars or behind? they go behind the bars. looks wrong but its right
10/27/2017 10:51am
yes behind
Falcon
Menifee, CA US
798th
10/27/2017 11:34am
Routed to the correct side of the frame? Not pinched between the frame and gas tank? Routed in the right location with regard to the tank bolts and any radiator mounts?
Dumb question: is it the correct cable?
Benton, LA US
10/27/2017 11:39am
TRy to adjust the cable as it sounds like you have no slack adjusted into it at all. You want about 1/8 throttle turn of free end play before the carb slide starts to move.
10/27/2017 4:08pm
Falcon wrote:
Routed to the correct side of the frame? Not pinched between the frame and gas tank? Routed in the right location with regard to the tank...
the cable is tight from the carb to throttle
ktm-5
Ravenna, MI US
10/27/2017 4:59pm
When we were on a 65 I got a throttle cable for a 85 and it'll allow u to run the cable in front of the number plate. I never used the 65 cable
Post a reply to: 2005 ktm 65sx throttle cable to tight
