Marysville, WA
Not sure what's up. Just finished this bike but I don't know prior history. I made sure the motor is grounded to the frame I check continuity there I also made sure the frame is bear where the coil mounts up and everything is grounded I check continuity through the stator in the pickup and they both seem fine the coil seems fine too but I'm not sure what kind of readings I'm supposed to be having any help would be truly appreciated
Have you tried unscrewing the plug cap from the coil wire and then cutting that wire back by 1/4" and the screwing the cap back into the wire. That is a good place to check as a bad connection there is common.
I looked for a free one for you online, but couldn't find one
It will be the best $12.50 you ever spend on the bike. Service manual will show all the electrical specs like how many Ohms of resistance the stator coils should have, etc. Plus loads of other good info to have. You'll learn a lot and most importantly you'll know your bike is rock solid (or if it's not, how to get it there!)
To verify this is the problem....Cut the wire as previously stated and then redo your OHM reading on the secondary side. If still not good, then replace the coil.
You replaced the coil
You checked the ohms for the stator and pick up, but try after heating with hair dryer.
You checked the connector pins front and back for a broken wire or pin on harness? Continuity check.
Pick up, stator, or harness? I would say CDI but you checked one with the same year bike.
Let us know when you figure it out.
Specs okay according to Manuel but must be they say those specs and have you replace stator if in those specs
So new stator later runs great first kick plenty spark
87.4 ohms and 235 ohms on new stator
174ohms and 232ohms on old stator
Witch is in there specs
Just a thought.
Post a reply to: 1994 cr125 no spark.
