- Pick trends
- Create a private league
- And more!
Temp = 80F
Barometer = 29.96inHg
Elevation ~ 500ft
Humidity = 58%
Slide = 5.0
Pilot = 30
AS = 3.0
Needle = 44-73
POS = 3
Main = 450
Observations: The 5.0 slide is probably good for the coastal San Diego weather where I live BUT it's not the best for the Pala desert where I ride. I'm going to have to test more slides until I nail it. I guess I'll go the 5.50 next and on to the 6.0 if need be. I needed to drop pilot to 27.5 for these conditions however, I did not have one on hand. The next size I had was a 25. Overall much better but there is still a bit of a bog off idle that can be cleaned up. If wasn't terribly picky, I probably wouldn't really notice it at this point or think it was just normal. The power is definitely smoother and more controllable than it was from the factory. Plug reading is also much improved as you can see in the pic...just a hair too dark.
The !7' and 18" KTM's, 250-300's, really need a leaner slide, 5.5 or #6. With the leaner slide it will clean up that area that you are describing, and you will be able to use OEM needles. I'm pretty sure, but check to see if your 18' uses the s-4 needle jet. With the s-4 and #6 slide along with a 42-75 needle in the #3 clip, start out with a 30 pilot and 450/460 main jet. Those setting should get you in the ballpark."
It looks like digger was spot on if you want to try a 5.5 slide. I'm still waiting on my #6 slide, I already have the s-4 needle jet and the 42-75 needle. Thanks for doing the hard work for me so I know what to go straight to when my parts show.
Why are you going to the S-4 and 42-75 needle again? The 17's have the S-1 which seems to be fine unless the larger cutaway becomes an issue with the S-1 and 43-73. Where did you get a #6 slide?
No problem on the leg work lol. I'm a mechanical engineer and a chronic tinkerer...this stuff is fun to me
Pic from one of the freelance photographers at Pala...
https://www.motosport.com/dirtbike/oem-parts/kawasaki/2004/kx125/carbur… . They are about $20 cheaper thru Rocky MT, and I stock. RM wouldn't let me post a direct link to their Kawasaki OEM page.
thanks
My spare head showed up today. Anyone have recommendation on where to send for squish tightening and rechambering to maintain stock compression? I was thinking about sending it to XPR Motorsports in Murrieta, CA. I spoke to Chad about the Huskatoom 250 for about an hour and he seemed to know it well. Sounds like he has a really good porting package too but, I'm not ready for that.
Post a reply to: 17' TC250 Jetting Help
