IE
10/13/2014 9:04pm
hi I have a 2012 450 rmz. I weigh 105kg s , so I put in a 6.0 back spring and a 4.9 front springs .there ment to be the right springs for my weight .when I put them in .I found the front was way way too soft. I got the front revalved .to hold it up in the stroke . it worked well .but still is a bit harsh in the mid stroke unless I run less rebound dam, then the fork feels great .but rebounds to fast .and the front does nt have enough traction. wondering if I run less oil , will this help with the midstroke stiffness ?? . also I feel like the bike still feels so unbalanced . the back end feels to high, and hard . I was running 110mm sag 37mm free sag .the only way I am getting it to feel balanced is to run 3 3/4 high speed .so today I tried 115mm sag and the bike felt better, but still high and hard ,in the back? ,it feel s like the spring rate is wrong . would I be better putting a stock 5.8 in and try get it to 100 - 105 sag , would this balance the bike out . I read on the net that some guys were running softer spring s in the back on rmz s for this prob , has anyone heard of this , thanks
Example: I have a bike that their chart called for a 6.8 rear spring and what is correct is a 4.8 spring.
All I am telling you is that the chart is not always correct for the rear. I have not found the same to be true with the fork springs as they seem to come in right on the money.
You may want to give them a call and speak with them and ask that your shock rate and fork spring rate be double checked.
Do you happen to know what make/model/year this was on? We'd like to address it and make sure it gets corrected.
Also, everything we sell is 100% guaranteed, so that means if we recommended the wrong spring rate, we'd exchange it without question.
Also, if you ever want to double check a spring rate recommendation, shoot me an email over to chris@racetech.com and I'd be more than happy to run it by our R&D team. We gather rider feedback on our spring rates and settings daily, so we generally would catch any errors pretty quickly and are able to give solid recommendations. The calculator is pulling data based on feedback to the R&D department.
And remember, if you do choose to order springs, mention VitalMX for a 20% discount.
Post a reply to: suspension help on an rmz 450 please!!
