- Pick trends
- Create a private league
- And more!
CamP, I know they slightly lowered the compression in 2011 (it was actually to make the bike 1-world standard, same as the Euro, AUS bikes, etc along with the stupid long muffler), but even my 2006 will run great on 91 pump gas provided I jet for it. But then I will get a slight bit of spooge and slightly less crisp throttle response and the combustion chamber and power valve get more gunked up. So, I just stick with the 100 and it runs great.
You can throw fuel at the problem, but as you stated, you end up over-rich. The best option is to add enough good fuel to allow crisp jetting without detonation. My personal solution is to run 100LL avgas in all my stock compression 2-strokes and 110 race gas in my high compression bikes. That way I have enough safety factor to jet crisp, and my baseline never changes.
For the guys that are bound to pump gas, I'd suggest that they have the head milled to add volume, and reduce compression. That way they can have the peace of mind that their bikes will never burn down due to insufficient octane.
In conclusion, 100LL is a great fuel to use in any race application given: you can run leaded fuel if you're in a race, and you jet slightly richer due to AvGas' lower specific gravity. It is better than most VP fuels and I'm pretty sure that it worked out to be slightly better than VP's C12.
Feel free to ask questions about AvGas because it is a highly misunderstood topic...
I've been running 100LL for 35 years. It is great 2-stroke fuel, but it does not have enough octane required for the ultra-high compression in my mod CR. When measured like auto fuel, 100LL has an R+M/2 closer to 99 octane, as told to me by a fuel engineer. The R+M/2 octane requirement for my CR is closer to 104, so I have been mixing 100LL and VP110 50:50 to keep that engine healthy.
AvGas, source: Exxonmobile.com Note: these are the lean numbers. So in a race type jetting setting, you will get slightly higher than these listed.
RON, not given. Instead they use PN (performance number, which from my understanding is generally RON give or take 5) 130.0
MON= 99.6
PN+MON/2= 114.8
Oxygenated: No.
Lead content: .56 g/L
We'll compare to U4.4 because of its popularity. Source: VPRacingfuels.com
RON= 114
MON= 103
R+M/2= 108.5
Oxygenated: Yes, sadly.
Lead content: I believe I remember seeing .6 g/l but cannot find that anymore.
Another benefit is that AvGas is highly resistant to vapor lock. We can see from here that they are generally about the same. It all depends on if you believe in RON or MON or in this case PN. For both fuels you will need a richer setting. VP because it is oxygenated, AvGas because it has a lighter specific gravity than most fuels. I find it interesting to compare these numbers!
It has nothing to do with elevation, when we go up in altitude in the helicopter or airplane, we just simply lean the fuel-air ratio.
Increasing your octane is a good start - especially since your jetting appeared to be reasonable. You guys also have to remember, every pump in the country that says 93 on the handle isn't going to have the same fuel. There are bad batches and there are tanks out there with all kinds of contamination. For all you know, it could have been 87 octane coming out of the handle. Running at the ragged edge is also going to leave you no room for bad gas, for a jetting error, for operating the bike in too cold of a temperature, for a mechanical issue (powervalve binding). It is asking for trouble.
In theory, that bike should be able to run on 93 octane. I guess you could say it hasn't blown up yet, so it's "working." My first start would be to do a 50/50 mix of your most reasonable race gas in the area. If it's a crank seal leak, you'll figure that out soon enough if it keeps acting up.
Anyways, Micahdogg is right, start with higher fuel grade, then check other things if problems persist.
Anyone see any problems with my "game plan"?
Thanks again for the replies!
Most of the lower power, normally aspirated planes, used 80 octane fuel, which was red. Larger and turbocharged engines required higher octane, leaded 100/130 was green. You could not run the 100/130 consistently in the smaller planes, as the amount of lead tended to foul spark plugs. When 100LL (blue) was introduced, it was used as a replacement for both types. Many small planes do not really need 100 octane, but lower octane avgas is not produced, there is not enough of a market to justify it.
Many small planes run fine on automotive fuel, but it does require an Supplemental Type Certificate (STC) and formal approval. In most cases the only modification required is changing the placards on the fuel caps. One problem with current mogas is that in many states it contains a large among of ethanol, which is a problem if it is to be used in a plane. Another is that few airports stock auto fuel, for logistical and liability reasons: it requires separate tanks and pumps, and if they were to pump mogas into the wrong plane and there were any issues, they would be sued.
A side note: many old military piston engines were designed to run on 115/145 (purple). Since it is no longer commonly available, the examples you see at airshows have to limit throttle settings to allow the engines to survive on 100LL.
Another characteristic is in how it is refined, to aid in preventing vaporlock!
Regardless, I was merely supporting what CamP was saying in that AvGas has been a great fuel in 2-strokes for a long time, and personally Reiterating the emphasis on the benefits of fuel quality as well as octane. While many should learn to utilize density readings to tune, the simplest place to start is with the suggestion of a basic idea to use a fuel (In any bike), that will provide consistency in performance.
To summarize, cleaned carb and installed 180 main and 50 pilot. New wiseco piston, crank, bearings, seals, etc. Set timing to stock at .007". Going to start troubleshooting after work but figured I'd see if anyone had any obvious ideas.
Pull the plug out and lay it on the cylinder- are you actually getting spark?
Is the plug a little wet, indicating that fuel is making it into the cylinder?
Also check the hour meter wire in the spark plug cap.
FYI: Your spark plug cap looks beat up. I think this may be your problem.
Your hour meter wire could be giving you a problem and not allowing the spark energy to reach the spark plug.
Then I did the source coil tests and got no reading for source coil 1:
I then put the leads directly onto the stator where the black and black/red wires are soldered on, still nothing.
https://youtu.be/b3p-gmcInis
Post a reply to: YZ250-Extreme Pitting Problems
