Jacksonville, FL
3/18/2015 2:39pm
I have a 2004 KX125 and every time I change the oil it takes me about 1/2 hour to get the bike to switch through the gears. At first it's stuck in neutral. I can get it into 1st gear and then it takes about 5 minutes to get it into second, going back and forth between 1st and neutral. This process continues for all of the gears. The strange thing is that once I can get the bike through all gears cleanly the bike shifts perfectly. Does anyone have any thoughts as to what might be causing this? I haven't inspected the plates or anything yet. Thanks
It would not click into gear and felt jammed after reading this we went and loosened the oil drain bolt and bam it went straight into gear
Brilliant thanks
Post a reply to: Transmission problems 2004 KX125
