Please log in first.
Start_new_topic
Forum Main ›› Race Shop ›› Tapping a water tank for Pressure Washer
Participating Members
Vital MX member -eagle-
Vital MX member indy_maico
Vital MX member babba boey
-eagle-
South Point, Ohio
Quote
11/5/2009 1:05 PM
Just got a 55 gallon plastic water tank for washing at the track.
I was wanting to keep it set up vertical and tapping a fitting on the low side of it.
Has anyone did this and could you give me some advice?
indy_maico
Indianapolis, IN
Quote
11/5/2009 1:27 PM
You have a Parker distributor in South Pont called Huntington Hose & Hydraulics Inc
Go down there and tell them what you want to do and they will fix you up with some tasty valved quick disconnect fittings so that you can just plug a hose on the tank when you need it.
Depending on the wall thickness of the tank, you might be better off with a bulkhead type fitting with o-rings rather than tapping it into the plastic.
-eagle-
South Point, Ohio
Quote
11/5/2009 5:17 PM
Damn dude. You were all over that. I actually know a guy that works there. Thanks.
indy_maico
Indianapolis, IN
Quote
11/5/2009 6:41 PM
-eagle- wrote: Damn dude. You were all over that. I actually know a guy that works there. Thanks.
One Buckeye helping out another. Good luck with your project.
babba boey
Kuna, Idaho
Quote
11/6/2009 8:47 AM
I would run a 12volt rv pump between the pressure washer and barrel. It will eliminate pump cavitation and you can spray off helmet and other gear without running pressure washer.
Post a Reply to: Tapping a water tank for Pressure Washer
Please log in in order to comment.
