Joko Posts 1433 Joined 1/2/2011 Location Cromwell, CT US Fantasy 190th Joko 9/11/2015 - 5:04pm 9/11/2015 - 5:04pm Edited Date/Time 9/12/2015 4:53pm Should I flush with alcohol or gas? Or just pour the new oil in and run it for a few min then change it? Countershaft seal leaks and replacing seals, but suspect ATF can leak more...(2006 YZ250 2T) ? Save | Quote Log in or register to post comments DPR250R Posts 2129 Joined 9/14/2006 Location NJ US DPR250R 9/11/2015 6:00pm 9/11/2015 6:00pm No need to flush. Warm it up, drain and fill with new oil. Save Quote Log in or register to post comments JW381 Posts 10642 Joined 7/21/2009 Location Harrisburg, OR US JW381 9/12/2015 1:09pm 9/12/2015 1:09pm 2 strokes don't care too much. I reckon you could use vegetable oil and get away with it. Save Quote Log in or register to post comments Jakes Dad Posts 1865 Joined 6/22/2009 Location Brooksville, FL US Jakes Dad 9/12/2015 4:53pm 9/12/2015 4:53pm JW381 wrote: 2 strokes don't care too much. I reckon you could use vegetable oil and get away with it. And tractor hydraulic oil. Save Quote Log in or register to post comments Start New Topic Share to Facebook Facebook Facebook Share to Twitter Twitter Twitter Post a reply to: Switching gearbox from ATF to motor oil, need to flush? To post, please join, log in or connect to Vital using your Facebook profile Login with Facebook. Breadcrumb Forum Main Tech Help/Race Shop
Tusk Quick Draw Air Filter System Image Tusk Quick Draw Air Filter System $89.99 (25% off) Up to 25% off at Rocky Mountain ATV/MC
Odi V2 Emig 2.0 MX Lock-On Grips Image Odi V2 Emig 2.0 MX Lock-On Grips $26.99 (10% off) Rocky Mountain ATV/MC
POD MX K4 2.0 Knee Brace Pair Image POD MX K4 2.0 Knee Brace Pair $522.45 (11% off) Rocky Mountain ATV/MC
Tusk 4-Stroke Oil Change Kit Image Tusk 4-Stroke Oil Change Kit $18.29 (26% off) Up to 28% off at Rocky Mountain ATV/MC
Alpinestars Fluid Narin Jersey Image Alpinestars Fluid Narin Jersey $14.88 (60% off) Rocky Mountain ATV/MC
Tusk Low Pressure Dial Tire Gauge Image Tusk Low Pressure Dial Tire Gauge $12.99 (19% off) Rocky Mountain ATV/MC
Tusk First Line Air Filter Image Tusk First Line Air Filter $11.88 (41% off) Up to 41% off at Rocky Mountain ATV/MC
Tusk Curved Tire Iron Shop Pack Image Tusk Curved Tire Iron Shop Pack $49.99 (17% off) Rocky Mountain ATV/MC
Tusk First Line Oil Filter Image Tusk First Line Oil Filter $4.29 (28% off) Up to 40% off at Rocky Mountain ATV/MC
Tusk Brake Bleeder Vacuum Pump Kit Image Tusk Brake Bleeder Vacuum Pump Kit $23.99 (31% off) Rocky Mountain ATV/MC
Dirt Tricks Zirconium Rear Sprocket Image Dirt Tricks Zirconium Rear Sprocket $125.99 $139.95 Rocky Mountain ATV/MC
FMF Factory Fatty Pipe Image FMF Factory Fatty Pipe $269.99 (10% off) Up to 10% off at Rocky Mountain ATV/MC
FMF PowerBomb Goggle Image FMF PowerBomb Goggle $42.00 (20% off) Up to 50% off at Rocky Mountain ATV/MC
Polisport Complete Replica Plastic Kit Image Polisport Complete Replica Plastic Kit Up to 53% off at Rocky Mountain ATV/MC
Motorex Cross Power Full Synthetic 2T 2-Stroke Oil Image Motorex Cross Power Full Synthetic 2T 2-Stroke Oil $81.99 (7% off) Up to 7% off at Rocky Mountain ATV/MC
Primary Drive Front Sprocket Image Primary Drive Front Sprocket $8.79 (32% off) Up to 32% off at Rocky Mountain ATV/MC
Tusk 520 Gold X-Ring Chain Image Tusk 520 Gold X-Ring Chain $69.99 (15% off) Up to 20% off at Rocky Mountain ATV/MC
Motorsport Products MX Engine Stand Image Motorsport Products MX Engine Stand $159.88 (25% off) Rocky Mountain ATV/MC
Tusk Cable Luber with Champions Choice Cable Lube Image Tusk Cable Luber with Champions Choice Cable Lube $14.03 (14% off) Rocky Mountain ATV/MC
Tusk 170 Piece European Motorcycle Bolt Kit Image Tusk 170 Piece European Motorcycle Bolt Kit $31.99 (29% off) Rocky Mountain ATV/MC
