7/7/2015 8:16am
As title mentions, my 2015 crf450 squeal/squeaks through the airbox when trying to start the bike (which for some reason is now much harder to start)
Once it does start up the noise goes (unless I just can't hear it over the bike) the bike recently melted the ignition inside the flywheel cover because I lost all water from braking the radiator.
Head and barrel had absolutely NO damage, checked very thoroughly. Replaced all broken parts and replaced piston. Valves and clearances all fine too. Bike also fluctuates when idling. Compression all fine too. If you could help me ASAP would be very thankful as I have my current championship to contend this Sunday.
I would suggest you have an oil pressure issue.
If the engine got hot enough to burn the stator then it got hot enough to damage the crank bearings as well.
Some guy just asked that same question in the "two stroke edition" of MXA....not sure what month it was. Either June or July I think.
Make sure both sections have the correct amount of the correct oil in each.
Good luck.
Post a reply to: Squeal noise when starting CRF450 2015.
