Bloomingdale, GA
1/24/2014 6:53pm
I just recently purchased a new primary drive o-ring chain and put it on my yz. After 3 rides the chain fell apart at the master link area. The same thing happened to a friend of mine with his crf250f. I couldn't find the old master link so I decided to reconnect the chain without it. My question is, will the chain be stronger or weaker without the master link? I have also concluded that I will never buy an O-ring chain again, they are a pain in the butt!
Primary drive chains arent top shelf but I have had pretty good luck with them.
Know something else I figured out that works here in Florida? Put your new chain on and hose it down good with your favorite lube. Ride. Hose it some more. Ride. Scrub it with a wire brush before every ride and then hose with lube.
I kept going through chains and sprockets way too fast. After almost every ride I'd take my chain off and thoroughly degrease and clean it, yet I kept wearing the darn things out in 2 or 3 months. I started asking around and some guys were getting months and months out of their chain and sprockets. "What's the secret?" says I.
The response was invariably something like, "I just wire brush it and lube it and keep it tensioned right." My theory is that once a quality lube gets in the pins and seals them up, the Florida sand just sticks around them and actually helps seal up the chain. When you completely degrease and clean the chain after every ride - more fine sand keeps getting in there and wearing on stuff.
It's just a theory, but my chain and sprockets last a long time now.
Post a reply to: Primary Drive O-ring Chain
