Athens, GA
4298th
11/2/2014 7:23am
I spotted a small scratch on the case half of my vintage KX125 resto tonight. You can see the nick in the center of the photo below. This is an Ebay case because the oil bung on my original case was broken from PO.
Question is will Yamabond fill that in and seal, or am I fucked?
Question is, can the nicks be filled in? Cases for this 1989 model are NLA and any NOS case halves are long gone. This is the third case set I've bought on Ebay and each turns up new surprises. This one is the best of the bunch.
@Lumpy, the scratch is adjacent to the crankcase. A leak here would allow air in, creating a lean situation. Has to be sealed up one way or another.
@PawPaw, I changed the OP since I was thinking scratch and typed "crack". sorry for confusion.
Of course all the engine internals (transmission, etc) have to be removed in order for the cases to lay flat on the glass
I've done several cases like this. I used to be one of those "weld it up then machine it down properly" guys, but have since decided it's just an old bike and just a sealing surface. It needs to be flat, and remain in place when the case halves are screwed together. No drama
I now fill those kinds of nicks/scratches with JB Weld, then smooth somewhat with a plastic smoother, as if you were applying body putty.
After it cures, do a quick lapping as described above to assure flatness, then assemble with the sealer of your choice.
I've had good results with the Yamabond type sealers.
on the edge of the case so you get best bond possible. Yamabaond cures to a very rigid finish. The
pressure change from outside the case to inside the case has no chance of breaching that if you clean the
aluminum well first.
TM
Post a reply to: Nick along edge of case half. What to do?
