- Pick trends
- Create a private league
- And more!
http://www.lasleeve.com/downloads/2-stroke-break-in-procedures.pdf
If you do decide to use it, here's something else that might help after break-in:
http://www.procircuit.com/jetting-specs.htm
Lucas will be fine to run all the time.
We have used it for the past 10 years with no oil related issues @ 32:1 mix ratio.
It works!
Blow-by is a recurring theme on my used pistons tho, maybe I am doing something wrong.
and cylinder wall. Never had a problem with ring sealing or premature wear after hundreds of top ends.
Not using synthetic oil during break in is because that oil has a lower level of friction (by design) which impedes ring seating,
IMO. Once the rings are seated, break in is complete and you can switch to your favorite brand of oil. Kawasaki used to market
a special "break in" oil just for that purpose. It was a non synthetic oil with some additives. This debate has raged for years and
has degenerated to "what ever works for you". On the one hand you have Kawasaki with the special break in non synthetic oil
and on the other you have Porsche (yes Porsche uses NIKASIL coated cylinders), breaking their engines in with full synthetic
Mobil 1.
As for using something like WD40, I have used WD40 to clean a freshly honed cylinder after the soap and water step, and I
like to use it when I'm test fitting parts like tranny gears and others that will be hand rotated to prevent dry metal on metal
contact. But I switch to a film of the appropriate oil for all of the above before final assembly. Since WD40 is meant to be a
water displacer (thus the WD), I'm not inclined to trust it as an assembly lube - but that's just me. CamP is expressing his
opinion on not using premix oil because there are always going to be different "techniques" for doing the same job. This,
like the synthetic, non synthetic debate comes down to the same "what ever works for you". I have a friend that tells me
that I should only assemble my clutch packs dry. He is adamant that soaking the friction disc in oil keeps the clutch from
breaking in correctly. Of course I always soak the friction disc in oil anyway, just like the manual says, and of course, the
clutch always works fine. In my experience, the manufacturers do a good job of putting out accurate information on the
best way to assemble and maintain their products. The same goes for your top end, Honda specifies lubricating these
components with two stroke oil during assembly in the service manual for your bike. Normally, I defer to the people that
designed and built the engine whenever there is a question, but again, that's just me.
dogger
I use a syringe and get pre-mix behind the rings as well as all over the outside of them. Also squirt is all over the main bearings and the little end bearing.
Should I not use any oil on the rings and cylinder?
Post a reply to: ..
