Phoenix, AZ
1/26/2016 11:40am
I decided to change the packing on my silencer since it's leaked tons oil on my swing arm. Discovered it looks like the previous owner(s) hadn't ever repackaged the silencer. The carbon build up is crazy. I've been having to poke out the holes in the core bc they were so clogged. I'm like 60% thru but it's taking forever. Can I soak it in anything to really get that deposit off? Also, I can only assume there's as much in the pipe as there is in the silencer. Is there something I can soak that in as well? I'm not going to burn any of this stuff off. I need a solvent. Anyone have success? It's an fmf pipe and possibly an fmf silencer off a use 99' CR250 I bought.
You could always find some sort of nasty kitchen cleaning products like caustic soda, however I'm not sure how kindly the bike parts would take to the stuff.
First time you start the bike up make sure you get it good and hot.
https://m.youtube.com/watch?v=OsfzGyb7ilA
https://m.youtube.com/watch?v=TU3r4vK33r8
Step 2: Use Castor 2-stroke oil cu'z it smells bitchin.
Step 3: Repeat step 1 many times.
(Note: If using synthetic oil skip step 3 and just continue riding and having fun not cleaning massive amounts of carbon)
What are you going to repack the silencer with?
Use the gas torch to burn down the pipe. When it gets hot and starts smoking put some light compressed air down the pipe. Don't do this in your garage or anywhere there is a possibility of fire.
https://youtu.be/6mVFAmLBimA
Post a reply to: How to clean inside of 2 stroke pipe and silencer
