BE
10/7/2015 2:40pm
Hello.
I want to polish my engine cases for my project http://www.vitalmx.com/forums/Race-Shop,42/2000-CR250-Ricky-Carmichael-…
Not a "mirror" polished finish, but more like a scotchbrite finish.
Did some research on this forum for some tips and how to's, and i came up using green scotchbrite and WD40 as a lubricant !
So before sending my engine to the shop for disassembly to make work a little better on the cases, i tried polishing a small spot on the left case half and came up with the finish i was hoping for.
When i finished this spot, i clean and degrease it, but then comes the problem, when i touch the spot with a clean dry finger, it leaves a stain on it. It comes right off after cleaning, but as soon as you touch it again it's back.
I used this polish method also on my chassis and didn't had the problem then.
Am i doing something wrong here ? I mean how will i explain my mechanic not to touch my cases when assembling my engine lol
In other topics i read people use SOS pads as finish, maybe this is the problem ???
I appreciate any help or other methods.
Thanks,
Bryan
Thanks,
Bryan
That's the only problem with polished aluminum is that it's raw metal. It will be susceptible to oil, grease, dirt etc.
I clean everything with red scotch brite pads
I think the finish of vapour blast will give a 100% perfect finish.
Brought my engine to the shop yesterday for stripping and next week my cases will be shipped to Holland for vapour blast.
After some research i saw that alot of people use this method for bike restaurations.
Here is the Quote:
"The process uses water, micro beads, mild cleaning agents, and air. These components are mixed into a slurry and propelled at high speed toward the surface of a metal part, such as aluminum, brass, as well as mild steel. It seals the surface, resulting in cosmetic enhancement and imparts a micro finish that helps it resist further staining and oxidation."
I suggest the place I sent my cases to http://www.vaporblastsolutions.com/
Dan did a great job. The cost plus return shipping was $70. Mind you these are bare cases.... and he also helped me out big time and pulled a couple of blind hole bearings for free. Dan is a super nice guy.
Here are my cases.
Post a reply to: Help appreciated on polishing engine cases
