Morganton, NC
I'm very new to this and I really hope you guys can help me. I was in the middle of a race and my bike quit and wouldn't kick start back up. Got back home it cooled off and cranked right up. Wasn't sure what the problem was so I had a top end put in and the valves adjusted. The exhaust valve was a little off so I thought that was the issue. Got the bike back together, kicked it, started up, and it ran fantastic. However, once it got warm, it wouldn't Kickstart. It would bump start everytime. It only kick starts when it's cold. I need some help!!
When was the last time you changed the spark plug?
Something is changing with heat and causing your problem?
If it were in my shop I would get it hot and do a leakdown test to see if a valve leaks when hot.
Standard rule of thumb if a bike will start cold but not hot, but will bump start hot we always go to the valves and check clearance.
Post a reply to: HELP!! 2014 KX250F wont kick start warm
