New City, NY
7/6/2014 6:22pm
I changed my gear oil on my 2006 YZ 250 yesterday and the oil was a grey color. I change the oil after 2 or 3 rides since I bought it new and its never been grey. I heard the coolant can be leaking thru the water pump seal, but the coolant level hasn't changed. I also heard it can be from the clutch. I'm using a clutch kit I never used before from Driven, it only has 4 rides on it. It seems funny the 1st time using this clutch and the 1st time the oil is grey. Any ideas and thought would be appreciated.
silvery? = metal and/or fiber plates in the oil.
Gray? Possibly both. (Hey, it happens.) I would change your pump seal first; even though you say you aren't missing any water from the radiator, it doesn't take much to change the color of your oil.
If all that is still good, I'm worried about your transmission gears.
What oil are you running? Maybe switch it up to another brand for a while. It may also be as simple as not getting all the old gray stuff out when you change oil - try "flushing" the tranny out with a few quick oil changes using cheap oil.
Also, the water pump has 2 seals with a weep hole between them. So for water to get to your oil it would have to get past 2 seals and you would see coolant dripping from the weep hole (unless your weep hole is packed with dirt or corrosion).
The YZ250 has steel plates stock, not aluminum.
Like others have said, likely deterioration of the aftermarket fiber plates. Stick with stock.
Post a reply to: Gray Gear OIl
