Greensburg, PA
6/13/2017 10:51am
Alright so it wrecked pretty hard to find out that my front wheel is no longer aligned right. When the bikes propped up and I spin the wheel, at one point everytime around it squeaks. Bunt the rim doesn't wobble. So maybe the axle is bent, but that probably hasn't been touched since the bike was put together in 06. So it's not budging and I've tried all my strength, with a pipe and everything it's not budging at all. So any ideas?as you can see the axle isn't in very good shape.
This is also how my wheel aligns as you can see the way my forks go, the wheel points to the right(looking at it) as my fenders slightly bent left
Either turn the bars to the stop and kick it straight or you can loosen the pinch bolts on the triple clamps and finesse it back to straight.
Don't know if you really bent the axle, but to check take it out and roll it along a flat surface. Any kind of bend will be apparent in the axle if it "hops" along or a gap can be seen when rolling on a flat surface.
Do that and then get back to me about the brake squeal.
straighten wheel the best you can, Spin the front tire and hit the front brake, do it a couple times and then hold the brake, tighten pinch bolts.
its always worked for me.
I know it sounds obvious but make sure your pinch bolts are loose on your front axle.
To straighten the front end you need to loosen all the pinch bolts up on the triple clamps, get everything straightened back up then using a torque wrench, re-tighten the pinch bolts to 16.5 ft. pounds. Make sure the fork tubes are both sticking out the top of the clamps the same before tightening.
If you crashed hard enough the axle may have jarred a little sideways causing the torque on the nut to increase.
If the axle spins a couple revolutions with all the pinch bolts loose go ahead and tighten the two pinch bolts opposite of the brake caliper and nut to hold the axle. Then try loosening the nut again.
Question....That bike is now 11 years old and you have stated that " the front axle has never been removed", so I want to know how the front tire has lasted so long much less the wheel bearings and seals? It would seem that regular maintenance is running a bit behind schedule on the bike.
Post a reply to: Front wheel alignment help?
