NC
5/3/2015 9:11am
The front rotor on my YZF drags the pads constantly. I can spin the wheel fast as I can but it comes to a stop in just a few seconds.
The rotor is a Galfer SKW with about 10hrs on it. Its not bent, I put the stock rotor back on to experiment and it also drags. If I pull the caliper off, the wheel is very free. It will actually bob back and forth as it slows down until the rim lock is bottom center. Pads have 20hrs on them and are in good shape. I resurfaced them with 180 grit sandpaper on a piece of glass, they are flat. Caliper pins are clean, straight, lubed and have very little wear. Pad pin is new. I flush my brakes every five hours so the system isn't full of goo. The rotor flange on the hub is clean and checked flat with a straight edge.
I saw a video a while back where Tickle's mechanic spun his front wheel and it kept spinning freely. I want my wheel like that.
Anyone have any tips or tricks to try before I order piston seals and possibly pistons depending on their condition?
Pull backwards on the lever and see if the wheel spins better
I'm thinking if I pull the pistons I will find crud packed up to the seal. The caliper is 10 years old with never a rebuild.
On a normal bike, a front tire should spin freely for 3-5 seconds before stopping. That is pretty good. It sounds to me that your bike is fine and you don't have any problems, you are just expecting to achieve a result that is unobtainable with your current parts.
It would still be a good idea to pull your pistons out to clean them and replace with new seals. You would be surprised how gunky they get even with good maintenance.
Another trick for a serious racer is to cut the metal spring out of the hub seals. This will allow the wheel to spin with less friction because the hub seal is not applying pressure to the axle, but I don't recommend this because it drastically reduces the life of the bearings due to exposure.
It's possible the caliper mounting lugs on the fork are bent or the caliper mounting bracket itself is bent. I've seen both happen a few times. My buddy bent the mounting lugs a little by hitting the caliper on a rock on a left turn with a deep rut. He replaced nearly every damn part until he realized the lugs were bent. He ended up using a straight edge sanding stone on the mounting surfaces to bring them back into alignment.
Thanks for the reply. I know I don't have a "problem", and I think I am being realistic. The wheel spins very free with the caliper off, 20 sec or so. Its not a matter of ceramic bearings or "cheap" steel bearings. The friction stopping the wheels rotation is not in the bearings, its from the pads dragging on the rotor. The dragging is excessive, and not normal.
How's the skw OS rotor set up?
- thinking of ordering for my rm 250
- seems to good of a price vs performance?
Gonna order new pads also, probably sintered?
I'm very picky with my brakes, especially the front, which is partly why I want to get the dragging eliminated. I flush them out all the time and I absolutely cannot ride someone else bike if their brakes are sub-par.
- now I have to order them tonight and some pads and enough left over for a read rotor and pads
Post a reply to: Front Brake Rotor Drag
