Frig Off
2/10/2015 5:54am
Bike is a 2014 TM 144MX. I'm putting in a new piston and rings. I did not take stock measurements prior to teardown.
I decided to try a 0.1mm thinner base gasket, as I know they are a bit conservative with the heads on these bikes and I run full race gas. I just hope it won't cost me too much top end.
Squish is now 1.05mm, which is what I was looking for. I know I can go with less and still be safe, I had 0.85mm on my Husky but 1.1mm was recommended to me.
Head volume is 11.1cc, which I'm not sure of. I was told that 12.8cc is optimal on this bike. Would a 0.1mm thinner base gasket put my measurements off by that much? Or is 11.1cc fine?
I measured by finding TDC and filling with oil through the spark plug hole until the oil reached the bottom of the threads. I did not fill to the top of the threads as I figured I was doing it correctly.
I'm using Renegade SX2, which is 104 octane and 5.6% oxygenated. From time to time I will run VP C12 mixed 50/50 with non ethanol pump, also. I'm ok with it if I can't mix anymore.
I did another head volume check, this time filling to the top of the spark plug hole and I got 13cc, which seems more along the lines of what I've been told I should be aiming for. I guess this must be the normal measurement used.
I mistyped about my base gasket change, it is 0.1mm thinner, not 0.01mm as I stated in the original post. Still a very minor change but I wanted to be technically accurate.
You're not going too far off course with the squish, not a big worry.
Strictly my uneducated way of explaining this.
http://www.gasgasrider.org/html/measuring_squish.html
Would the fuel in the cavity of your sparkplug account for the missing cc's?
You have two circles, one is the bore, 58mm?? Pi r squared. The squish area is the total area minus the area of the smaller circle, then you can do the percentage calculation
When I get home, I will post a pic of the tool I used to measure volume with the head removed, really easy with a flat top piston
Post a reply to: Engine builders, how does this head measure up?
