MA
8/29/2015 11:14am
I want to put an electric 1800 psi pressure washer in my trailer with a 50 gallon water tank. I'm not opposed to a gas powered but the electric may work better for space saving and putting in our camper when we don't have the mc trailer. I also live in an apartment so could use it to sneakily wash my truck with a 30 gallon tank in the back of my truck. Would I need a small pump to supply pressure to the pressure washer? Anybody done it? I know I've seen it at the track but never thought to see how it actually works. Thanks
TM
Also, you can use a voltage inverter to change the 12 volt batter power to 120v to run the power washer and the water pump can run off of 12 volt. So no need for a generator, just a marine battery and an inverter will do the trick.
Harbor freight has those too in many different sizes. Just be sure it will handle the washer power draw. You can also hook you a solar panel to keep the battery charged and those too are available at Harbor Freight.
I have an inverter, battery and solar panel on my trailer to run the 110v lights, 12 volt lights, 110v air compressor, security system and hand power tools when needed.
55 Gallon drum. ($15 at local feed store, free from local car wash if you can find a good one)
290 GPM in line water pump. (harbor freight, $30)
12v car battery (had one laying around, $60 if you have to buy one)
Troy Bilt 2800 PSI 2.3 GPM Gas pressure Washer ($300 if new)
Various hose attachements ($25 from Lowes)
I got a 3/4 bung fitting from Lowes and drilled the hole about four inches from the bottom of the drum. After I attached the fitting I screwed in a one inch straight high flow nozzle that has a shut off valve that the hose attaches too. I have a 6 foot hose that attaches to the high flow valve coming from the tank and the other end attaches to the in-line water pump (hose was included with the water pump). The discharge side of the pump has a 10 foot hose that connects to the pressure washer.
That is it. The 1 inch high flow adapter that I set up coming off the tank really helped me get the necessary flow for pressure consistency. I hope this helps someone that is trying to set-up a pressure wash system for the track.
Cheers-
http://en.lavorwash.com/products/view/independent-1900
I have had one for 3 or if it is 4 seasons. Used about 1-2 times a week during half of the year. Better flow and pressure then in most electric ones for home use.
Post a reply to: Electric pressure washer and water tank in trailer anyone done it?
