Drill holes in my piston?
Edited Date/Time 5/9/2016 3:32am
02 cr125. Brand new oem cylinder and a pro x piston kit. There's no holes where the exhaust bridge is, the kit says nothing about drilling holes like how the Weisco kits do. Should it still get two holes? Thanks
CrGuy2T
Santa Fe, TX US
3719th
5/8/2016 11:32am
No don't drill holes in that piston.
Paw Paw 271
Benton, LA US
5/8/2016 1:43pm
If has the exhaust bridge, I would suggest doing the holes for proper cooling and lubrication at the bridge area.
There is no down side to doing them, but there is a big down side possible if they are not done.
Just my 2 cents worth ( based on over 45 years of motorcycle mechanical work experience.)
CrGuy2T
Santa Fe, TX US
3719th
5/8/2016 3:28pm
Pro x is a cast piston. Only reason I suggested against it.
Paw Paw 271
Benton, LA US
5/8/2016 5:37pm
Either way , the bridge needs to be lubricated and cooled no mater what type of piston is run.
CrGuy2T
Santa Fe, TX US
3719th
5/8/2016 6:37pm
I'd be afraid of it cracking being cast. Totally agree on the lubrication. I personally have a had good luck on all my cr 125's with cast piston not drilled. Cr 250 was notorious for having bridge problems
colintrax
Taylorsville, GA US
2363rd
5/8/2016 7:01pm
CrGuy2T wrote:
I'd be afraid of it cracking being cast. Totally agree on the lubrication. I personally have a had good luck on all my cr 125's with...
Yeah, a cast piston isn't gonna take well to drilling. OP if you do drill holes, please take a file to it.
Skerby
Mayes County, OK US
5/8/2016 7:26pm
I just put a cast pro x piston in my yz125, it came with two holes drilled for the exhaust bridge.
NHtoWA421
Bremerton, WA US
5/9/2016 3:32am
put a bit of a chamfer on both sides of the hole if you drill it. it will reduce stress in that area and prevent the chance of a crack propagating from that hole.
Post a reply to: Drill holes in my piston?
