6/10/2015 7:32am
Hey guys, I picked up a clapped out 96 CR250 recently, and after riding it for about 5 minutes the transmission started acting up. The bike is locked in second gear. When the shifter is pushed down as far is it will go, the bike is in neutral, and when it is returned to the center position, the bike is in 2nd gear. Furthermore, when the shifter is lifted up, the bike will not switch to a higher gear, and seems to only lift about half as much as I would expect. The bike is disassembled right now, and the motor is pulled. I've got the clutch pulled out and can see the gearshift linkage and shift drum etc, but I'm not sure what I should be looking for.
Is the problem I'm describing sound like a problem with the gearshifter assembly, or is my problem likely in the transmission which is going to require me to split the cases and inspect gears and shift forks etc.? Any help is greatly appreciated.
This is a parts drawing of your shifter drum and etc. In most cases your problem will be with one of these parts.
#11,12,14,16,17 &18.
Broken or worn bushing, broke or missing springs in the dogs or return spring or broken or worn shifter detent arm and roller.
Also be sure that the center shift drum bolt is tight.
Post a reply to: 96 CR250 transmision problem
