10/21/2016 12:47pm
can someone please help me with my bike, I just got a 2017 150 sx and its running rich with a bit of spooge coming out the exhaust , my main problem is thou my 1st and second gear are really boggy until I get in higher rpms I'm running 40:1 with good syn. oil, and I'm in Ontario Canada my elevation is about 186 m, I'm guessing its my pilot I'm just not smart when it comes to carbs just know the simple stuff, its setup from factory right now for 301m-750m ASO 1.5 IJ 45 NDL 43-74 POS 3 MJ 470, someone please help I love the bike but 1st and 2nd gear are driving me mad, also the plug is really dark and oily , I have 17.5 hours on it , haven't fouled the plug yet for being to rich, but my oil I use says it prevents fouling so I'm guessing that's the only reason I haven't yet. Thanks
My son is moving off the Supermini KX and I have been researching this but luckily I found a National Build 16 model with 4 hours.
Good Luck!
Took 2 1/2 months to get a leaner needle, but finally got it running decent. 470 MJ, 42-76 top clip position, 40 PJ, 1 1/2 turns out on the AS. I race XC so I went up to a 49T rear sprocket,
You are considerably lower elevation than me so I would start at 480 MJ, 42-76 2nd clip, 42,5 PJ, 1 1/2 AS.
The other option is the JD kit which I will test in the near future.
Don't waste your time trying to order needles from Sudco - the CDN Mikuni distributor, they don't stock any nor will they bring any in. Yamaha Canada is another dead end - they have zero stock on any size YZ125 needles. I ordered a needle outta Yamaha Japan 6 weeks ago, I was suppose to have it 2 weeks ago - nothing yet.
KTM finally has stock on them.
Your floats will be off by a mile, I have been into 7 or 8 2017 Husky/KTM 150, 250,300 and all had a float level of 5,5 to 5.8 mm. At this setting you will be going through fuel like a Funny car. Buddies XC250 with the big tank ran out of fuel on a casual 35 KM trail ride. He needed another litre to get back to the truck, so 35 KM = 11 litres of fuel.
Mikuni's spec is 8.7 mm..
Go down 1tooth and there's less snap, but gain top speed.
Is your bike missing the ignition side crank seal because something is really wacky here.
Post a reply to: 2017
