8/8/2014 8:34pm
have purchased a set of WP factory ktm suspension (conevalve, trax) for a 2014 350sxf with the 25mm front fork axle. As i am thinking of upgrading sooner rather then later to a 2015 350sxf it has the new 22mm front axle in which i will not be able to use 8k worth of factory suspensions that has just been delivered. does this mean if i keep the forks i will have to buy a wheel and axle from a 2014 sxf ? Could be an expensive upgrade ? If im right with this theory then beware of the small "costly" change over. will WP start selling factory forks with a 22mm front axle mount in them ?
thankyou
thankyou
If you're lucky you just have to change the spacers and possibly the wheel bearings. I bought an older (2012) set of a60 wheels for my 2014. I just needed to replace the spacers to newer ones.
Post a reply to: 2015 KTM 22mm axle ? 25mm Cone Valve forks wont fit ?
