- Pick trends
- Create a private league
- And more!
Understand that if the TPS sensor is bad you will not get the up ward movement in the voltages. The service manual should help you on this.
Also understand that the popping can also be from a bad exhaust gasket at the head. Was the pipe removed without replacing that gasket?
Other thing to check/replace is the fuel filter inside the tank. If it's blocked it will give the symptoms you mention.
https://youtu.be/VkY8npCaXgA
For my Honda 250f I have a full dynojet system that allows me to add different maps via the laptop, and I have a Vortex on Husky 250f that is excellent too. however, I had great results on the 2012 CRF450 with just the piggy back.
I tried replacing the fuel filter, nothing. Brand new fuel pump, nothing. Also replaced the injector itself and MAP sensor. I will look into the tuner, What did you use it to change on the bike exactly? Air/fuel mixture?
Mine was doing the same thing of popping under deceleration and hesitating when you chopped the throttle. The JD tuner worked very well for me although I know proper tuners like the Vortex or Dynojet Power Commander are much more sophisticated and give more options.
Post a reply to: 2012 crf 450 tps problems
