Le Nord
7/13/2012 7:12am
While racing on the weekend, I noticed that my YZ250 would go into (what I would describe as...) a false neutral. It did it quite a few times during the moto. The next moto the shifter completely locked ( I am assuming in 3rd)
I have not had a chance to open it up and take a look yet... but was wondering if anyone else has had the same problem and might know what to look for...
My first and un-educated guess would be that I may have bent a shift fork.
I haven't raced this bike often, actually it has very few hours on it, so I was a bit surprised by this.
If anyone has any ideas/info, I would appreciate it...
The shift drum seems to be completely locked in place. Would this mean badly bent shift forks?
Looks like I have to split the cases regardless, unless anyone has another idea..
The 250 though, I only have about 6 hours on it and raced it twice and this happens.
Good to hear from a fellow "MXVET.com"!!
I recently purchased an '08 with low hours, and it started having shifting issues the third time I rode it. Split the cases, found a broken 4th gear and gouged out shift drum where the broken pieces had been wedged between it and the case. Everything else looks fine, but now that the tranny/shift mechanism is reassembled it still won't shift correctly. Sometimes it runs up and down through the gears just fine, but sometimes it just can't make the jump to the next gear. I bought one of these things new back in '06, rode it for a couple years and never had any problems at all.
The problem was the end spline (clutch side) on the main axle. A couple of the splines sheared off and became lodged in the shift drum therefore locking it in 3rd.
I'm guessing the main axle was defective.. luckily no other damage was done.
Thanks for your opinions guys..
Bought all new gears and main shaft and it has been fine ever since.
Post a reply to: 2008 YZ250 not shifting
