Reno, NV
1/27/2012 6:25pm
I have a 2007 YZ450F. I have just finished cleaning the carburetor and reassembling the bike. I replaced the air filter (which was extremely dirty) and put in a new one. The bike has spark but will not fire. I tried pull starting the bike but that didn't work. The bike won't start. Can anyone help me?
Mine is:
1 choke
2 blip throtle 1 time to prime
3 grab front brake lever and squeeze it hard. (This stops you from blipping the throttle while kicking.)
4 kick it hard
5 when it fires let it idle for 30 seconds
I don't know why anyone would remove a spark plug and put the old part back in. If your questioning it......replace it.
Valve is......slightly what? Tight? Loose? Yes it can and will keep it from starting......its that old compression thing.
How much time is on the bike? Last time you put a piston & rings in it? Last time the valves were adjusted to put them in spec? Last time it ran? Is there gas in it?
I'm am not the first owner of this bike. The bike doesn't have a lot of time on it. It started showing trouble in Ocotillo Wells last summer when it just died and wouldn't start up again. We brought it back to Reno and changed the spark plug. It started up and we road for a little bit but then it just stopped. I took the bike apart to get to the carb and spotted an extremely dirty air filter. I cleaned the carb and reassembled the bike with a new air filter.
Could the coil be the problem and not the spark plug? However, I can see a spark on the spark plug so it's not dead.
Should I try manualy squirting gas through the spark plug whole to try and get the bike to fire?
I am going to guess you dont have any/much experience wrenching on your bike by your comments. Thats OK..... we all had to learn.
REPLACE THE SPARK PLUG! Its cheap and can be the whole problem.
Air filters can be cleaned and re-oiled.......they rarely need to be replaced.
Coils rarely go bad but.........My own 08 YZ450F just had the stator go bad.
The air filter is a double arrangement so I doubt any dirt got past the second filter (it was clean when I took it off). However this would still be blocking air flow.
Should I try adjusting the air/fuel mixture and see if that helps?
Motor needs - Fuel, Compression & Spark to run......whats missing?
I've replaced the spark plug and I have looked into the barrel of the carb. The spark plug is 'sparking' and the carb is squirting fuel like it should.
The only conclusions I can make are that...
A: The spark isn't strong enough and can't ignite the gas/air mixture. Therefore the coil or the magneto has a problem.
B: The gas/air mixture isn't right and won't burn. Which is unlikly because it was running fine before.
I'm hesitating on bringing it to the mechanic as this will be costly.
When starting I twist the throttle 1 time to squirt/prime when cold. If the compression is good and it has spark + the prime it should fire/try to start if only for a second till the prime burns out.
I would get the valves properly adjusted. If that does not fix it I would replace the stator.
Reseting the getting to the valves and fixing them will take time and reseting the timing chain may cause more problems.
Further, it seemed like I was getting back pressure from through the carb when I was kicking it with the air boot off. Should this be happening?
ps: Where is the stator on the bike? It doesn't say in the manual.
But I think I may have found the problem. The timing chain and the camshaft might be out of sink. This would cause the valves to open and close at the wrong times. However, to conferm this I will have to open the engine. I'm not sure where to start.
My guess is this engine has ingested so much dirt that it is simply worn out.
PS: No dirt got into the engine. Dirty air filter was not the problem.
Post a reply to: 2007 YZ450F starting problem
