Morehead City, NC
4/28/2016 2:35pm
Hey guys need some help here.
I have a friend who bought this bike for his son and really wasn't aware of the issues. Heres a quick overview
The frame, wire harness and Carb is a 2005. The engine is a 2002-2003. Had a hard time finding the right cylinder to match the bottom end.
The issue lies in the mixture and jetting. The bike will foul out BR8ES plugs within 10 minutes of riding. The mixture he had to run to eliminate that had to be changed to 50:1 (VERY LEAN) Also switched to a BR7ES. Jetting is 410 main, 50 pilot and 2 on the air screw.
Heres where it gets a little weird... Pulled the plug out today and it is soaked. Oil still spitting out of the exhaust and covering the swingarm fender and brake caliper. The bike has absolutely no bottom end whatsoever. Also running 13-52 gearing. Whole engine top and bottom have 6 hours on it.
Im not sure where to even start on this thing. His son races hare scrambles in the B class would like to be somewhat competitive. He already dumped a ton of money into suspension, tank and rebuilding the engine (nightmare) so I'm just looking to help him out with getting this thing running somewhat decent so he can finish out the season on this bike.
If anyone can shed some insight into this it will be much appreciated.
When the engine was rebuilt, were new crank seals installed?
Was the carb float height set correctly?
Is the float needle sealing correctly?
Are you sure the exhaust valves are working correctly?
When you out the engine together did you check the squish? ( Sounds like you may have a miss match of parts)
Did you do a compression test?
A leak test?
float is in spec
needle and seat are new and sealing perfect.
i will be checking the exhaust valves after work.
i would hope that the engine builder checked the squish.
the complete engine is an 03
compression is good
leak test was also good
Im going to mess with the jetting tonight, repack muffler and check the powervalve. if that doesnt work ill be getting the pwk carb.
I had a 2001 CR125 which had the drooling and smoking issue too. It turned out the right side main seal had pushed out and it was sucking tranny oil into the crankcase. Luckily, they are easy enough to replace.
https://youtu.be/dgAFKKY88nk
https://www.youtube.com/watch?v=dgAFKKY88nk
I looked at motosport.com's site and part #16 is not noted so I can't tell if it's a seal or bearing. (link below)
http://www.motosport.com/dirtbike/oem-parts/honda/2003/cr125/exhaust-va…
Also, did you say the head looks bad? Do you think it has a blown head gasket? You said the leakdown test was good. Would it hold pressure/vacuum if it had a leak into the cooling system? (I'm curious for my own knowledge) I would imagine the cooling system would be under a ton of pressure and somewhat blow the cap off if you loosened it immediately after running.
Another thing: My buddy (assumed he) had a broken carb on his '97 yz250. He went through the carb several times and there was no visible cracks but the only remedy was a new carb. You might be on the right track...
That bearing, even if bad should not keep the valves from opening. I would think the linkage or the governor may be the issue. ( but none of these would cause the oil issue this started with.
You said you did a compression and leak test....What were the readings on these test?
I am still leaning towards a bad crank seal on the clutch side.
Post a reply to: 2005 CR125 chassis and carb with 2003 CR125 engine...HELP
