8/29/2014 1:33pm
Hi guys,
I have a 2004 cr 85 big wheel but there's a problem with getting a spark. It will sometimes spark but its weak and usually won't start, if it does start it bogs down when you rev it then dies and won't start again. Does any know what this could be?
Thank you
Thank you
If not, then you will have to do an ohms test on the coil.
Also check the flywheel and stator for dirt and rust as well.
how would i do a ohms test?
thanks
I have a project 1993 YZ250 which has no spark. I will be investigating the issue soon. I don't have a service manual at this time...
Ryan
so CDI's can be bad but still work they will just produce a weaker spark.
if you put in a new plug and it runs but wont start after a few laps or 10 then its likely CDI related.
Thanks motodad422 I'll give it a go
Ryanlester761
Post a reply to: 2004 cr85 running problem
