Mansfield, OH
Alright so i have had this kx all year and it ran great with no issues. I think ive put maybe 7ish hours on it all year. I put a fresh top end in back in February. Valves are at the proper clearance.
I was riding about 2 weeks ago and the bike ran great all day and i went to ride it one last time and it wouldnt start. Brought it home, checked my valves, the timing, cleaned and oiled the filter and put a new plug in. It started right up and ran fine. Turned it off and tried to start it again a bit later and it wouldnt start. I put a new plug in and bam it started. Then the same thig happened again after i turned it off. So i put the previous plug in and it started and did the same thing. Im beyond confused. It was super dusty when i rode last so maybe the fuel injector is clogged? Im not familiar with the EFI part of the newer bikes. All i know is is when i kick it it sounds like it fires once and then nothing. Ideas?
I would also suggest using a fuel filter sock in the fuel tank as the fuel coming from the gas pump can have crap in it that can work it's way to the fuel pump filter and then into the injector. That crap can cause an early death to the fuel pump as well.
Post a reply to: 09 kx450 starting issue
