Worden, IL
8/26/2015 8:24am
Hi all, back again with some more bike problems. I bought the bike about a year and a half ago. When I went to change the oil in it after I bought it, I noticed the previous owner had cross threaded the drain bolt. I bought a helicoil and had that put in. Note: I did not put it in because I am not too mechanically inclined. All was well until this year.
Ive only had the bike out once this year which was about 2 months ago and it was in a sandy area. I got home and washed that bike and nothing was wrong. A few weeks ago, I noticed an oil puddle underneath my bike. I did some research and checked for small cracks in the case and didn't notice anything. I removed the bolt, cleaned everything up and put fresh oil in it. It started leaking oil again almost the next day. Its a fairly large amount, enough that I am not comfortable riding the bike.
I have no clue where to go from now. Maybe I missed a small crack? I think the bolt is the issue though because the oil is collecting on the end of the bolt. Again though, I am not mechanically inclined so I'm probably wrong.
Any help would be GREATLY appreciated. Thanks.
1) New washer and bolt (make sure you torque it to the right spec!)
2) Flexible sealant on the bolt threads. This will be a pain and you will have to clean it off every ride and re-apply. I'm just talking a very small amount on the threads new the flange, not on the end that sticks into the oil
3) New heli-coil
4) If all that fails, try to have a ZERT installed or look for used cases on Ebay.
Post a reply to: 06 yz 125 transmission oil leak
