1/14/2016 7:56am
Hi guys, I am pretty new to this forum, so would just like hello to my fellow MX community, firstly.
I have just acquired a 2004 CR250r, it has not really been run in anger for a few years, so I cleaned the fuel system out, cleaned the carb, replaced the air filter, put a new sparkplug in and replaced the chain along with a few other little bits. I pulled her out at the weekend and fired her up, she ran well for around 10mins then I was about to switch her off, after turn the fuel stop tape off (just to drain the carb), she start to run at around half revs and wouldn’t turn off. I removed the HT lead and removed the CDI unit but I think the HT lead was still touching the engine and giving the spark to the sparkplug as she was still running. I removed the fuel line and after a minute or so (felt like hours, thought I was in for a full engine re-build) she stopped running. I noticed she drop a bit of coolant and there appeared to be a little bit of oil/fuel discolour (slight shine) in the coolant. Am I right in thinking that this would the gasket perished, allowing oil in to the engine which was keeping the bike running?
Any assistance and advice would be highly appreciated.
Thanks in advance
Thanks in advance
I would not run a 2 stroke out of gas on purpose. No fuel also means no lubrication too.
A knackered head gasket wouldn't allow oil in to the cylinder on a two stroke, only on four stroke if there is an oil gallery near where it has failed and even then it would only run away if it were a diesel.
Mr Happy, not heard of dieseling before can you explain that to to me please? so it sounds like it would have been running lean as the fuel tap was turned off.
Also what would I need to do to rectify this?
Thanks guys
With the fuel tap off it could have been running lean enough. If it has stood for a long time it could have done in a crank seal. Could be the inlet perished. There are plenty of guides on the net to help you diagnose what it could be. A leak test would be a good start.
Thanks Paw Paw 271
If it does it again hold it wide open, believe it or not it shuts them down.
That trick is for 4 strokes only.. No premix.
Invest in a leak down tester
Post a reply to: 04 CR250r will not stop running
