Anonymous (not verified)
10/3/2015 11:07am
- Took a beat, dented, tired old looking Pro Circuit Works pipe and after a refinishing process, here is the result.
- Also, in a similar condition, took a Pro Circuit Platinum pipe, sand blasted and refinished in Works.
1. Pro Circuit Works Pipe Refinished
1.) I sandblasted the Platinum pipe myself and also wet sanded both pipes;
2.) The next part is the proprietary sauce and I wish I could say I did all it myself --- Pacific Crest Pipe Repair.
3.) Pacific Crest Pipe Repair in Oregon pulled all the dents, cleaned the pipe and completed the "Works" finish you see in both pictures. Turned out great in my opinion.
4.) Connect with Scott at PCPR and tell him you are looking to get the Works finish done to your pipe. Only downside is shipping costs to/from that makes the process relatively costly.
Hope that helps
They don't charge much to do it, however, as I noted the shipping cost to/from is what makes it costly.
I think for sandblasting off the platinum/chrome finish you need an abrasive media, and a lot of sanding to make smooth again.
Post a reply to: Pro Circuit Kx Works Pipe - '01 Kx 250
