Saraland, AL
5/3/2015 9:26pm
If anyone knows if this engine is similar to any other engine and if maybe what piston would work in it would be helpful. Im thinking on doing a top end on it but haven't a clue as to what piston would fit it. The pipe is pretty ragged also is there a aftermarket one still available?
As for parts here is a start. http://partsfinder.onlinemicrofiche.com/gofasters/showmodel.asp
Want to make it a 144? http://www.goforwardmotion.com/pistonsandgaskets.php
http://www.gasgasmotos.es/en/previous-models/models-5-2000.html
http://www.gasgasrider.org/
These guys are one of the best = http://www.halls-cycles.com/
I know a little bit about GasGas, I've own one since 2000. Mine is a 99 EC200
As for the pipe, I'd give these guys a try, https://www.piperepair.com/ they have repaired my Messico pipe many times with good results. If your OEM pipe is a Messico, your going to be hard pressed to find a replacement here in the states. DEP, HGS mays offer a pipe.
Hope this helps.....good luck!
B8RES my 125 looks about the same as yours, plastic color and exhaust style (stamped). The link for the parts didn't pull up, any way you could check the link out and repost it?
Find the GasGas OEM parts link......they don't list a 2000 .MC or Cross 125, so look for a 2002.
The motor hasn't seem many changes over the years.
If your pipe looks similar to mine, more than likely it's a Messico.......
Post a reply to: Gas Gas MX 125cc 2000 year model
