Two stroke oil in Rotary engine?
RMZ290 (MD)
Vital MX member RMZ290 (MD)
3427 RMZ290 (MD) /images/default/avatar/c50.png http://www.vitalmx.com/community/RMZ290-MD,3427/all 04/01/08 1 60
3/3/2008 6:08 PM
Edited Date/Time: 11/26/2008 3:00 PM
A lot of the tuners seem to recommend premix at big ratios ie, 4 oz's per 14 gallons of gas. I'm kind of not sure what direction to go with my RX-8. They say only run a full syn like AMSOIL Saber Pro. What do you guys think? will I kill my cat, plug fuel pump or foul plugs? This is in addition to the stock oil injection system.
oldfart
Vital MX member oldfart
235 oldfart http://p.vitalmx.com/photos/users/235/avatar/c50_mandelalifeU_1372655121.jpg?1372654146 http://www.vitalmx.com/community/oldfart,235/all 08/15/06 12 11 1460 19739 4 3
3/3/2008 6:30 PM
Why do they suggest running premix?
"It always seems impossible until it's done." -- Nelson Mandela
jww347
Vital MX member jww347
3972 jww347 /images/default/avatar/c50.png http://www.vitalmx.com/community/jww347,3972/all 04/01/08 48
3/3/2008 6:53 PM
For seal longevity??
newmann
Vital MX member newmann
6232 newmann http://p.vitalmx.com/photos/users/6232/avatar/c50_614585238_1207253287.jpg?1294182303 http://www.vitalmx.com/community/newmann,6232/all 04/01/08 19 1 http://www.vitalmx.com/community/newmann,6232/setup 927 20087 8 54
3/3/2008 7:54 PM
Edited Date/Time: 4/16/2016 6:18 PM
Any clue what the ratio breaks down to with the stock oil injector pump? Always considered disconnecting it on my ported 12A 82 RX7 and just running straight premix.. Had the Mikuni /loop intake and Racing Beat header. Big noisy Holley fuel pump chugging away got me down the road at about ten mpg. I pulled an 86 Corvette up to about 70 mph. That kid couldn't believe some little p.o.s. import left daddy's Corvette behind. :D
Bonepony (MD)
Vital MX member Bonepony (MD)
3442 Bonepony (MD) /images/default/avatar/c50.png http://www.vitalmx.com/community/Bonepony-MD,3442/all 04/01/08 14 308
3/3/2008 8:20 PM
Edited Date/Time: 3/3/2008 9:22 PM
One of my friends has a few rotary-powered race cars, but none of them have any emissions gear. He runs 4 oz per 5 gallons in his cars. They're NA motors, and two are bridge ported, while the third is a peripheral port.
One of the cars is an ex-IMSA GTP Camel Lights Mazda/Tiga that he picked up about ten years ago. We fired it up once right after he got it, but it''s never turned a wheel since he's owned it. He finally took it to Roger Mandeville for a freshening, and we're supposed to pick it up Thursday. I'll try to get some pics of Mandeville's shop. He's probably the top rotary guru in the US.
Scotty
Vital MX member Scotty
3202 Scotty http://p.vitalmx.com/photos/users/3202/avatar/c50_98715650_1263633805.jpg?1294181222 http://www.vitalmx.com/community/Scotty,3202/all 03/21/08 36 1 413 4665 2
3/3/2008 8:54 PM
I have a few friends who run rotary engines in their sandrails. They usually do a 50 to 1 ratio or so of max 927. smells awesome! Yes it is for the apex seals these engines use. They tend to wear out quickly when running alot of boost. One guy has a 3 rotor that puts out 750hp. Its pretty badazz!
A village in Kenya is missing its idiot
RMZ290 (MD)
3/4/2008 10:53 AM
Stock oil injectoion puts a minimum of a quart every 3000 miles, so I would say about 0.05 ounces per gallon.
Three rotors sound awesome, too bad they cost so much money to buy and get running.
Scotty
3/4/2008 3:31 PM
[quote="RMZ290":34p1johs]Stock oil injectoion puts a minimum of a quart every 3000 miles, so I would say about 0.05 ounces per gallon.
Three rotors sound awesome, too bad they cost so much money to buy and get running.[/quote:34p1johs]
That ratio sounds about right for a stock car. Some of my buddies are running upwards of 20 PSI of boost. Thats why they up the ratio a bit. Your car will be fine. You can find the 3 rotors at the junkyards for pretty cheap. And man they are alot of fun in a sandrail. I would imagine in a street car with some boost they would be a blast
newmann
3/4/2008 3:51 PM
[quote="Scotty. You can find the 3 rotors at the junkyards for pretty cheap. And man they are alot of fun in a sandrail. I would imagine in a street car with some boost they would be a blast[/quote]
3 Rotor engines in junkyards??? I thought the 3 rotor was either a race only motor offered through Mazda for race purposes and was pretty high dollar? I know the third gen RX-7 had a few builders(Pete Ferrell?) outfitting some cars with them.
RMZ290 (MD)
3/4/2008 4:09 PM
[quote="Scotty":2seb2gsc]I have a few friends who run rotary engines in their sandrails. They usually do a 50 to 1 ratio or so of max 927. smells awesome! Yes it is for the apex seals these engines use. They tend to wear out quickly when running alot of boost. One guy has a 3 rotor that puts out 750hp. Its pretty badazz![/quote:2seb2gsc]
No way anyone is finding a 3 rotor in a junkyard over here. Mazda had a 20b 3 rotor in the Cosmo is Japan. You can import them from Japan for around $5G's used. Most the guys the put them into the 7's and 8's claim around $12G's to 20G's to get them up and running well.
Scotty
3/4/2008 4:17 PM
You should email my buddy Josh at http://www.danzioperformance.com He is the mazda rotary guru out here. I know he has found a few of them at the junkyards. His car was one of the ones I was refering to that got 750HP out of it. He also did a couple of Toyota supra motors and got 1000HP out of them at 32psi. But they didnt do to well in the sandcars. email him, hes a really cool guy and will answer all of your questions
rubarb
Vital MX member rubarb
1770 rubarb http://p.vitalmx.com/photos/users/1770/avatar/c50_108580350_1238909587.jpg?1294179349 http://www.vitalmx.com/community/rubarb,1770/all 06/12/07 12 27 122 1935 11 3
8/9/2017 7:36 AM
What would DJ Paul (aka Premix Junkie) do?
MotoTribology
Vital MX member MotoTribology
50415 MotoTribology http://p.vitalmx.com/photos/users/50415/avatar/c50_download_1460130382.jpg?1460130158 http://www.vitalmx.com/community/MotoTribology,50415/all 01/13/16 1 6 202 4
8/9/2017 8:38 AM
Kept at a high enough ratio, like the 450:1 you mentioned, it shouldn't foul plugs, but if you use a 2-stroke oil with phosphorus additives it will decrease the cat's lifespan. TC-W3 marine 2T oils are the typical choice for UCL in passenger cars due to their phosphorus-free formulations. I don't think it would be any different for a rotary.
I'm just here for the oil threads.
"Never attempt to reason with people who know they are right" - Leto II
"Most believe that a satisfactory future requires a return to an idealized past; a past which never, in fact, existed" - Leto II
MotoTribology.com - Motorcycle Lubrication Education
newmann
8/9/2017 9:12 AM
Damn, someone must still be jacked up on the pain meds...
Love me some rotary.
MotoTribology
8/9/2017 10:22 AM
It's not like it's 9 years too late to bring this up is it?
scott_nz
Vital MX member scott_nz
6101 scott_nz http://p.vitalmx.com/photos/users/6101/avatar/c50_image_1405826384.jpg?1405825907 http://www.vitalmx.com/community/scott-nz,6101/all 04/01/08 1 68 2575 1
8/9/2017 11:23 AM
Edited Date/Time: 8/9/2017 11:24 AM
20 B, (3 rotors) came out in Mazda Cosmos, which was a japanese only model, they are still pretty hard to come buy, but you can buy them around here sometimes, alot of them came in as 2nd hand imports . (we get alot of japanese 2nd hand imports here)
guys down here are building 4 and 6 rotor versions now,
