AL
I have a 09 kx450f started get hard to start when cold so I decided to check valves both exhaust was .178 mm spec in .17-.22 mm and intake was .102 on one side and the other side I couldn't even get a .038 in there is that common and what size should I put to see what shim to start with and should I adjust the exhaust also even tho it's in apec?
intake spec .10-.15mm
thanks this is gonna be my first time doing this
I would suggest the purchase a set of hot cam shims for your bike, then you are covered.
Keep one thing in mind....Reshiming one or twice is ok, but after that you will need a valve job with new valves and some machine work.
Post a reply to: need help valve adjustment 09 kx450f
