Newark, DE
10/21/2015 8:14pm
So I'm installing my first air filter cage on my rm 125, and I want to make sure I'm going about it the right way. I'm removing the rear tire before installing along with the number plates, and exshaut. Am I doing this right? If you guys have any suggestions for me please feel free to school the noob haha!
What the reasoning behind putting a cage in it.
That is called the 'air box'.
Pretty sure a 99' RM125 will have to be done like this:
1)Remove the seat.
2)Remove the sidepanels
3)Remove the rear fender.
3)Remove the silencer (muffler)
4)Loosen the carburetor to airbox joint.
5)Remove the lower subframe bolts (2)
6)Remove the upper subframe bolt (and nut if there is one)
7)Remove the subframe assembly from the bike
8)Remove the screws that fasten the airbox to the subframe
9)Remove the Airbox
Reverse procedure to install the new one.
What is wrong with the airbox that is on it?
Here's a diagram:
sniff * sniff *
Good luck brave lil Zook7
Post a reply to: Installing a air filter cage for the first?
