Dover, NH
7/24/2014 3:32pm
once it gets to almost its top speed, the throttle seems to almost disengage (for lack of a better way to describe it). like it is reving really high and then it starts put put puting and then if i realease and repull the throttle it will go back up and then bog down again. even if i keep the throttle pulled all the way it revs high (like it should) then bogs down and then it engages for a couple seconds (and i can feel it accelerating) then bogs down and up and down and up and down. any clue as to what might be causing this?
If that doesn't work, it could be a stator heating up, once it gets going ??
Decarbonize the exhaust pipe with an oxy / acetylene or MAP gas torching. Start from the flange heating it cherry red , working your way back. Do the same to the disassembled silencer / baffle. Once it cools , tap it with a piece of wood to jar the carbon loose. Blow out with compressed air.
The baffling system in those pipes has very small holes, and becomes clogged after extended use, especially if the injector is set on the rich side.
You can get about 500-700 more peak RPM out of a PW by disconnecting the ignition control module . The one in the little rubber strap back by the airbox. Doing this will eliminate the start setting requirement on the handle bar switch, not AMA legal.
The exhaust port on the PW is located so low in the cylinder, that the full port area is not even utilized. That's why they take forever to clean out somewhat. Raising the exhaust port, and re-chambering the head, to get the compression back that is lost due to raising the port, will really wake a PW up.
We have pulled the carb, replaced the pilot jet, cleaned the main jet and circuits. The fuel seems to flow just fine when opening the petcock. Replaced the plug, there was no washer in the exhaust so that wasn't an issue. When kicked it will sputter for a few revolutions, but not run. Checked the switch seems to work as it should, but would be happy to bypass it as we won't be doing any AMA races for a while.
Any and all ideas are appreciated, prior owner said it ran when he put it away.
All of the electrical connectors on a PW are vulnerable to water. When wet, they simply will not rev / run correctly.
How is the cranking pressure? If below 90 lbs, it probably is not enough to start and run.
If it is an older PW or has a lot of time on it, check for a carboned up exhaust port / pipe / baffle.
Another problem on the PW is sometimes the crank seal behind the ignition goes bad, and won't allow good compression to build for proper running.
A used non runner PW I purchased actually had the seal pop out of the cases, it was sitting right up against the back of the flywheel when I took it apart.
And for what it's worth ,unplugging the ignition control module near the air box will add a bit of peak RPM, but a negligible improvement in overall running characteristics.
For a cheap hop up, run two or three base gaskets, and shave the head .010. This will raise the exhaust port a bit, and make them run a bit cleaner. Too much height on the exhaust port will kill the cranking pressure / compression ,though, so do not go too crazy unless the head is modified accordingly.
120 psi cranking pressure is what a good , fresh, stock PW 50 will put out on a gauge. They will run on 95 psi ,but harder to start, and very dull throttle response. The PW is also fairly prone to seizing the top end. A pinned down ring from a seizure will make for a weak or no run situation.
I used one of those .095 spacer plates under the cylinder base on a PW, modded head, clamp on Uni filter. Was not worth the effort really. Send the cylinder and head to Barr's if you want a good port / head mod.
The low geared QT 50 ring and pinion gear is the best dollar investment to make on a PW. Better low end pull, and only a slight loss in overall top speed. Corner to corner, it works well. Not sure why Yamaha did not spec the QT ratio for the PW , as stock gearing.
Post a reply to: problem with pw50
