Pittsburgh, PA
9/3/2014 11:27am
How should I clean my white boots? I have a pair of fox instincts and they are starting to get stained. Any advice on how to clean other than the power washer? What cleaner is best for white boots?
hung the boots up on the clips they have for floor mats used the tire cleaner option moved over to the bike then after a feew minutes rinsed them off.
way less effort then trying to spray them with my presure washer at home.
Cheers
Simon
Oh....and I've worn white boots for the past 15yrs. Just like the looks of them better.
Where can I get that stuff?
Some guys on here said it would cause damage to anodized stuff and so forth......after about 6 months of using it.....it has never dulled anything. And the bike is about as clean as you could possibly get it. It really is amazing. I would say and least twice to 3 times more powerful then simple green.
I wore white boots in summer because of heat from sun,sitting in staging at regionals or LLs can be long,the white is much cooler.
One of the nice things about Shout is that it works so well that you can leave the pressure washer in the garage. All you need is a spray nozzle on a garden hose. That is the key to keeping water from contaminating your bearings.
Post a reply to: WHITE BOOTS
