Santa Clarita, CA
5/14/2019 12:35pm
Looks like it has a gearbox and clutch. Just replacing the crankshaft with an electric motor.
For electric bikes, this is the way to go IMO. Don't know what the gas tank is for though. Guess in case you get thirsty, you can carry some water.
Whats the purpose of having radiators on an electric bike?
Edit: i'm a little to slow on the draw...
Sherco SE Electric, key points:
- engine: 144 V, 5400 Rpm (8000 max), liquid cooling by electric pump Bosh
- battery: Kokam LiPo technology, 7 V 15 Ah 2220 Wh (x4)
- time of refill 1 hour
- gear box: 2 sequential reports/ratios
- weight: less than 100 kg
http://www.moto-station.com/article12601-nouveaute-moto-2012-eicma-sher…
translated page on -> http://babelfish.yahoo.com/
Thank you for you post
I think it is good to see smaller brands coming back with innovation
The only thing holding back electric bikes is the range and battery weight. If they could do a small turbine or even diesel powered hybrid, you'd have the benefits of electric without the range issue. You can get a good amount of power out of a small engine if they are designed to run within a very narrow consistent RPM range. Certainly enough to power a generator.
The Evolt will have a 2 speed: a "normal" and a second shorter for the crossing and flying at low speed.
http://www.freenduro.com/nouveautés-produits-off-road/201111091231/prod…
Even if they offer a trans, with the E torque I'd think 3-4 gears would be plenty. The Honda proto doesn't appear to have a transmission.
http://www.motoblog.it/post/33753/sherco-enduro-se-electric-2012-salone-eicma-milano-2011
Post a reply to: "Sherco" Electric bike, with clutch and gearbox
