- Pick trends
- Create a private league
- And more!
My last van still ran like new and had good oil pressure and no noises at 225K when I sold it and that got fresh Rotela every 5 to 7 thousand miles.
http://www.calsci.com/motorcy did cleinfo/Oils1.html
Edit: And if anyone knows their stuff, I figure they do.
OP, if you go to thumpertalk and search on "Rotella", I promise you, you'll have (at least) a days worth of reading.
One of the most beat up threads of all time. Thumpertalk has page after pager of topics just like this.
So Rotella is ok for clutches I take it. You're running the synthetic Rotella T 15w 40?
Rotella T takes more heat than any other oil.
If it's ok for wet clutches, i'll give it a shot in the two stroke. I have been running ATF, but that stuff eats plastic (water pump gear)
I hope people realize that most oils labeled as "synthetic" are not 100% synthetic having only small percentage of true synthetic oil .
Post a reply to: Shell Rotella Oil??
