Lynchburg, VA
2/9/2016 6:36pm
Hey guys I have a 2014 yz250f stock motor and exhaust wise. This previous weekend I ran a mixture of Sunoco 112 and Sunoco 93 50/50 mix and I lost power especially in the bottom. Are there any recommended race fuels and map combos? Or am I best just sticking with 93 pump gas?
Period
(This is the single best tuning secret there is)
This bike flat rips the holey.....
WP Cone's on the bike.... now I'm spending my winter skiing, riding some and in the gym.....
Just running a race gas that has a higher octane rating will really not do anything for your bike to make it faster, unless it is tuned, or compression has been raised.
Higher octane burns slower! So with a stock motor it would make less power, the peak cylinder pressure would be lower, resulting less work on the piston. Now if you advanced the ignition timing, to allow the flame propagation to start earlier, that would increase the cylinder pressure, and the resulting horse power. Or increasing CR would help utilize the slower burn from the fuel and allow it to build more cylinder pressure.
Now race fuels like MR12 or U4.4 are oxygenated fuels, with varying octane ratings. oxygenated means that there are oxygen molecules in the chemical make up of the fuel...and we all know that more air makes more power. So in this instance, you are getting more air in to your engine by oxygen in the gas.
If I remember, I think MR12 has a octane rating of 87. Which is pretty low, which means it burns fast, which is good in my book. As long as the fast burn can be stable, it should net more power.
Up to you OP, but if you have a stock engine with stock mapping, should be no reason to run race gas unless you want a custom map.
http://www.racegas.com/article/10
But I guess I stand corrected. Thanks
Out of the pump fuels like Sunoco are made for automotive engines usually. Not worth the money.
IMO never mix race fuel with regular fuel. No ethanol is the whole point so adding it back in makes it worthless.
Correct or incorrect? I do know my bikes ran better on regular at Mammoth.
Actually see a gain from your efforts.
(that said, I hear most stock 4-strokes can run on pump gas just fine)
Post a reply to: Race fuel and remap
