- Pick trends
- Create a private league
- And more!
Some engines have a clutch setup that the linkage is in the cover ,it pulls the pressure plate . That would be a little more involved.
Ain't seen one on a full size mx bike in years since that made the cases a bit wider. Minibikes may still have that setup though.
Edit: don't forget to pump your rear brake, before needing it when riding, following this procedure!
Use a small-torque wrench on those little m6 bolts.
Post a reply to: Question regarding clutch cover replacement.
