Huntington Beach, CA
3/20/2019 9:32pm
Found this stuff at my local O'Rileys, I googled it and read good things about this Lucas Oil Semi Synthetic 2 stroke oil. Would like to exclusively use this stuff for a couple reasons.
1. Cost - At $9.99 a quart its roughly HALF THE cost of any other premix oil. Typically these days Im seeing Yamalube, Hp-2, and Maxima products going for close to $10 for a single pint! Making this stuff half that cost.
2. Its made by Lucas and they've always had a great reputation with oil.
3. Beach Yamaha (my local dealer) is no more, they are now called "Next Cycles" they are still a Yamaha dealer first and my experience with them thus far has been less than desirable, Steve was great to his customers....these guys ehh not so much. Even though I live 2 blocks away I'm not buying anything from these guys.
Seriously though, haven't heard a bad word about Lucas products, and for the price, I might think about it.
I'd say run it and see if you can tell a difference. (And if it smells good, so much the better!)
Edit: Mis-read that.
It had oxidizers in the oil ,dont know what or how.
You had to go a jet size bigger or more which meant it was indeed oxidized.
Most people dont know what they are doing and didnt rejet. So bikes that were right on the edge jetting wise seized up .
The oil got a bad rep real quick here and it disappeared.
I had been given afew cases and loved the stuff.
Oh, I forgot to add, don't mix this oil with whatever oil you ran in the past. I tried to get rid of my last bit of gas mixed with redline by topping off with gas mixed with Lucas, bad idea! It ended up separating the oil from the gas and the bike wouldn't run. Keep in mind this was years ago when I was even younger and even dumber so don't chastise me too bad!
Avidchimp: my current 250 is the first two stroke I have put an hour meter on so I don't know exactly how long I have gone on top ends in the past. If I had to guess it would be somewhere around 25-30 hours which is when I plan to tear down my YZ, so I don't do them more often due to the leaner oil mixture. To be fair though, I'm not a guy who generally tacs out a bike and revs the piss out of it, I prefer the lower rpm ranges just due to the lighter feeling of the bike and smoother suspension action at these ranges. My dad always swears by 50:1 in everything but if someone is a Barcia type rev machine I don't think a little more oil would hurt anything.
Oh ya, you're both motherfuckers!
I just stick with yamalube. I get it for around $9 a quart. Where is it $10 a pint ???
Should I replace the top end when I do this or just run all the gas out and then start with a full tank?
You can look on the Yamaha website and its 9 bucks for a quart.
*edit*
I have used Torco GP-7 and that is pretty damn similar to Yamalube 2R. 16 OZ to a fiver of gas and run it.
Post a reply to: Opinions and Experience with this 2 stroke oil
