Pittsburgh, PA
1/13/2015 7:14am
What is best to leave an o-ring chain soak in? I have new sprockets coming in soon, so I have been letting my chain completely soak in WD-40. It's been two days now that it's been soaking, is this okay for the chain? I've been hearing mixed opinions.
Just soak it in kerosene for an hour or so and scrub it with a hard brisled brush and then let it dry. boom, clean chain
The quickest way to kill a o ring chain is spray it with a pressure washer.
An o-ring chain is sealed with rubber gommets. So never use a pressure washer or hard steel brush on it, it will kill your seals and your chain will develop rusted links.
WD40 is crap for using on a chain, you'll need to rinse it after since it attracts dirt and dust.
http://www.vitalmx.com/forums/Race-Shop,42/RK-Chains,1228721
WD40 did the job of cleaning (It is totally worthless as a lubricant), and my chains lasted a long, long time using this method. Don't need to do it after every ride, just once in a while
Post a reply to: O-Ring Chain Maintenance
